mike12 Posted September 2, 2017 Report Posted September 2, 2017 Was wondering if you could help me out. Im trying to come up with a design for two NVX VCW 12s but all the calculators I used come out with diff results... I will be running on 2k NVX suggests 32hz with 1.85 cubes per sub, I would like them to play as low as possible without losing much output, my max space is 34"wide 23"depth 15"height would like the port in center between subs and on the same side as the subs thanks for your time.
