SoundQubed Amp and Sub Clipping - Looking for opinions!
46 minutes ago, dgreenie29 said:
I came up with 30.1 with a sine wave while testing the ac.
Ok, so that's about 900 watts at 1 ohm, so you are getting close to full power (you could never hear the difference between 900 watts and 1200 watts).
At this point I suspect either your box is holding back your output, or your expectations for what kind of output you should be getting might be a bit high.
Builds:
Thanks for the help along with everyone else!!! I did fix the box and evened out the port but it only improved slightly. My expectations may be a little high as I come from the good Orion HCCA and Memphis days and my last system roughly 8 years ago was a JL 12W7 on a 1000/1 which was really loud. I did learn how to check ac volts so I do appreciate that.
I might try and grab a Skar rp2000 and see if more power does anything otherwise I'll grab another sub and call it a day.
I will update you guys and let you know how it turns out, THANKS AGAIN!!!
  • Who's Online   0 Members, 0 Anonymous, 1616 Guests (See full list)
