Dual 10" SunDown for SD F250 center console question
MTHOMPSON
I have a few questions and I hope someone here can assist or maybe point me in a direction if not suitable for here:
Truck: 2015 Ford F250 Super Duty
#1
Looking to make a center console to hold 2 X10 v2. Now my space is rather tight based on the suggestion size on SD site. If I am to make it work, would like to have either:
The subs hidden inside; port firing down
or
The subs firing down; port firing down
or
I have enough space to raise the box off from the floor by about 5" (which is good for sub excursion; not sure if good enough for port and still have the overall height not too high (for an arm rest).
#2
With running dual X10" V2 D2 1500RMS, I was thinking (not really sure to be honest; lack of knowledge) of getting the SCV-3000D and running at RMS at 1 ohm : 3000-watts; thus running 1500watts to each sub. I know they are under rated at 1500watt RMS..but not looking to do HO alt/BIG3.
This would be on my stock dual 12v battery setup/stock alternator; with an addition of an XP XS3000 battery.
Help me get out of my single (behind rear seat) 13.5 JL audio powered by JL Slash 500/1.
Much Thanks!
How much space do you anticipate you have to work with?  Fitting two X-10s and doing it right sounds pretty challenging.
Builds:
I ended up purchasing 2 SD X8's due to limited size and also not to really need to do a HO alt at this point in time.  Hope to get center console out today so I can see/draw up an actual game plan.  I like the idea of the subs hidden within with the port aiming out the back.  As I think aiming down will just add additional vibration on my truck body.  With coming out of the back (towards rear seats) I should have about a good 8-10 inches of clearance.
P.S Nice FB page/designs!
  • Who's Online   0 Members, 0 Anonymous, 9060 Guests (See full list)
