Sub Box Design Help
I have two Vibe blackdeath spl 12" v2 1500W RMS subs and i've tried to design my own box but got no luck with bassbox pro.
Im looking for a ported box with the max sizes of         Width(side to side) : 900mm/35.43"         Height(up and down) : 650mm/25.5"           Length( front of vehicle to back of vehicle) : 800mm/31.4"
They will be powered by the vibe blackdeath mk14 v6 amp in paralell
Using 18mm mdf with a double layer baffle
If anyone could help it would be much appreciated.
TS PARAMETERS
Parameter
Series
Parallel
Revc
3.6Ω
0.9Ω
F0
34Hz
34Hz
Sd
53cm2
53cm2
BL
28.9 TM
14.4 TM
Qms
3.333
4.537
Qes
0.335
0.383
Qts
0.304
0.353
N0
0.283 %
0.269 %
SPL
86.5 dB
86.4 dB
Vas
23.623 Ltr
23.014 Ltr
Cms
59.018 uM/N
58.601 uM/N
Mms
358.295g
362.691g
Mmd
344.933g
339.329g
X-Max
15mm
15mm
Peak to Peak excursion
45mm
45mm
  • Who's Online   1 Member, 0 Anonymous, 603 Guests (See full list)
