Basskida Posted January 5, 2018 Report Posted January 5, 2018 Good day everyone, can i ask what is the best box tuning frequency can i make for outdoor listening (Open Area)? Is 38hz is ok? or can i go up with 40hz and up?
ShadeTreeMechanic Posted January 5, 2018 Report Posted January 5, 2018 It all depends on what you are trying to do. Is this a DJ setup for outdoor club or parties? Generally the lower you want to play out doors, the more power you will need to fill the space. Most out door PA style DJ setups are not tuned low because of this. I think 38hz would do well for most types of music and won't be much different from 40hz. I have 4 15s in my out door DJ setup. In sealed boxes with a resonant frequency of 40hz, It does great for the summer time block parties. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Basskida Posted January 6, 2018 Author Report Posted January 6, 2018 i have my small setup in my motorcycle tricycle, and unlike cars, my sidecar is not close cabin, i have 2 pcs 500rms 12inch sub tuned to 38hz in 3.81cu ported box
