is it safe to wire each voice coil individually to mono amp?
akuma4u
2 hours ago, slowfkncar said:
Well for the most part, that is a custom driver with no available paremeters and that alone can cause alot of trial & error, this is what i found works best for me.
With zv4 softies & the newer basket on zv3 motors off a 4500.1, i find 2.2 net,35-40 sq.in of port tuned to 32hz works well for me.
Same woofer off a 2500.1, i prefer 2.5 net,35 sq.in of port tuned to 32.
I use both enclosures for music, but alot of 28-45hz songs.
i only have 2000rms.. secondly.. what i was told is that the megaroll surround requires different amounts of airspace and port area (or only port area im not sure) vs the SPL surround. I have the SPL surround. I know the SPL surround makes the bandwidth larger and not so focused on the low end.. which is what i want.
the best i can do is around 2 cubes with 36sq in of port off 2000 rms.. i can decrease port area and increase my net volume a little but im sure that woofer needs plenty of port area..
the only other option i have is to do an aero port or external port..
are you using a megaroll surround on yours or a spl surround?
if jacob fuller uses this site in the sundown section, then maybe i should create a thread over there for this just for more input/advice.. i wish i just got the standard zv3 recone parts..
  • 1 month later...
Have you guys heard of CES (Custom Electrical Services)? I got my alt from them for my 2011 toyota corolla, not a single issue yet. 170amps at idle, 240+ @ 2000rpm
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
I emailed my buddy. $405 shipped for 250 amps for your vehicle....
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
  • Who's Online   0 Members, 0 Anonymous, 1754 Guests (See full list)
