Aussie Basshead Posted February 26, 2018 Report Posted February 26, 2018 New member and first post I have a volt gauge hooked up to my main battery and a CT Sounds Bass Knob with volt gauge hooked to my mono amp.. For some reason the bass knob reads 0.8 - 1 volt higher all the time Anyone have a idea why thanks
8ten8 Posted February 26, 2018 Report Posted February 26, 2018 Welcome to the forum. Maybe your "volt gauge" needs to be calibrated. Do you own a multimeter?
Aussie Basshead Posted February 26, 2018 Author Report Posted February 26, 2018 1 hour ago, 8ten8 said: Welcome to the forum. Maybe your "volt gauge" needs to be calibrated. Do you own a multimeter? Yes i do
8ten8 Posted February 26, 2018 Report Posted February 26, 2018 Did you/can you calibrate your volt meter?
Aussie Basshead Posted February 26, 2018 Author Report Posted February 26, 2018 45 minutes ago, 8ten8 said: Did you/can you calibrate your volt meter? How would i do that. Are you talking about the one hooked to the battery or the one with the bass knob thanks
Aussie Basshead Posted February 26, 2018 Author Report Posted February 26, 2018 1 hour ago, 8ten8 said: Did you/can you calibrate your volt meter? This is the volt meter https://www.ebay.com.au/itm/Mini-Blue-LED-Digital-Display-Volt-Monitor-Voltmeter-DC-12V-Voltage-Gauge-MA1005/201771241241?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 This is the bass knob https://www.ctsounds.com/products/universal-bass-knob
Wishuponasub Posted February 26, 2018 Report Posted February 26, 2018 You would have to crack it open and see if there is an adjustment dial. Or do some research and try to find out. Find out which one matches your multimeter and use that one. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
Aussie Basshead Posted February 26, 2018 Author Report Posted February 26, 2018 6 minutes ago, Wishuponasub said: You would have to crack it open and see if there is an adjustment dial. Or do some research and try to find out. Find out which one matches your multimeter and use that one. cheers.. I searched google before posting on here but couldnt find anything on my issue
Aussie Basshead Posted February 26, 2018 Author Report Posted February 26, 2018 All fixed.. There was a small dial on the left, put a screwdriver in there and matched the meters together
Wishuponasub Posted February 26, 2018 Report Posted February 26, 2018 Awesome. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
