movepage Posted May 26, 2018 Report Posted May 26, 2018 Hi all, I have a head unit that delivers about 5.2 volts pre out at max power with no clipping - making it a great unit. But the fact is after the RCAs (using RF 20 feet) i am getting about 2 - 2,5 Volts. I am woundering if iam having rca issues or if this power drop is normal? Changing RCA, is it going to improve? What brand and model do you recommend? Thanks in advance Movepage ————————————————————————————————————— HU - Alpine - CDA-9887R Changer - Alpine - CHA-S624 Amp - RF - R600x5 Front Speakers - RF - P165-SI + Alpine SPG-10C2 Rear Speakers - RF - P1650 Sub - RF - P2D4-10 on Vented Box
Crazy 8s Drums Posted May 26, 2018 Report Posted May 26, 2018 The gains on the amplifier are what compensates for this. RF RCAs are excellent. Orion XTR amplifiers Skar subs
movepage Posted May 26, 2018 Author Report Posted May 26, 2018 Hi Crazy8s Drums, You are righ, I have no complaints regarding the sound coming from the RCA’s - they are great. But, I was under the impression the amps gains where there to regulate the amplifier sensibility to the input signal that is regulated by the radio volume knob, and not to increase the voltage, is this concept incorrectthen? The point is I have 20foot and in the very extraem situation I have a drop from 5.2volts to 2.5volts that is 2.7volts - if this was a 2v head unit, the signal would’t Reach the amp, is there any way I can improve on this? Thanks Filipe ————————————————————————————————————— HU - Alpine - CDA-9887R Changer - Alpine - CHA-S624 Amp - RF - R600x5 Front Speakers - RF - P165-SI + Alpine SPG-10C2 Rear Speakers - RF - P1650 Sub - RF - P2D4-10 on Vented Box
Crazy 8s Drums Posted May 26, 2018 Report Posted May 26, 2018 Changes in the volume knob on the deck result in changes in voltage in the RCAs to the amps. The standard length of prefab RCAs for car audio amplifier kits is 17ft so your 20 ft length is not at all extreme. I have a 2v RCA output on my HU and the amps in back don't have any problems with it. I don't think you have anything to worry about. Orion XTR amplifiers Skar subs
Crazy 8s Drums Posted May 26, 2018 Report Posted May 26, 2018 I would advise against running the RCAs alongside your power cables though. Current running through a conductor creates a magnetic field around it which can induce noise into speaker wires and RCA cables. Try to route your power cables on one side of the car and your RCAs on the other... Orion XTR amplifiers Skar subs
AlpineNut Posted May 26, 2018 Report Posted May 26, 2018 10 minutes ago, Crazy 8s Drums said: I would advise against running the RCAs alongside your power cables though. Current running through a conductor creates a magnetic field around it which can induce noise into speaker wires and RCA cables. Try to route your power cables on one side of the car and your RCAs on the other... That is how ive had mind since they were installed in Las Vegas, and ive done that many times an never had a issue, plus I always use shielded RCA's 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n
Crazy 8s Drums Posted May 26, 2018 Report Posted May 26, 2018 You haven't had issues because you wisely used shielded RCAs! I don't know if Movepage's Fosgate RCAs are shielded, but Fosgate isn't known for selling junk so he should be fine. Orion XTR amplifiers Skar subs
Crazy 8s Drums Posted May 26, 2018 Report Posted May 26, 2018 In my case, I wouldn't have been able to stuff the 1/0 cable and the three RCAs into the trim together. The 1/0 barely fits by itself! Orion XTR amplifiers Skar subs
movepage Posted May 26, 2018 Author Report Posted May 26, 2018 Hi Crazy 8s Drum, Thanks for the tip, will take me some time to do it, and I will rerout the RCA’s to the drive side and pass them below the drivers seat. However i don’t have much option when getting all the cables in the trunk. Changing the rout of the cables, will reduce any unwanted noise, but still does not explain the big power drop I am getting - unless it s normal. I am getting more than 50% loss just on wire resistance. On your system, at the point of connection to the amp, do you read 2Volts or less? Thanks in advance Movepage ————————————————————————————————————— HU - Alpine - CDA-9887R Changer - Alpine - CHA-S624 Amp - RF - R600x5 Front Speakers - RF - P165-SI + Alpine SPG-10C2 Rear Speakers - RF - P1650 Sub - RF - P2D4-10 on Vented Box
movepage Posted May 26, 2018 Author Report Posted May 26, 2018 Hi , the RCA’s I am using are the RFI-20, the key features are: Split center pin for secure connection Great sound transfer OFC (Oxygen Free Copper) for corrosion resistance Platinum plated ends for corrosion resistance RFI and EMI noise rejection Frosted outer sheild for durability and flexibility ————————————————————————————————————— HU - Alpine - CDA-9887R Changer - Alpine - CHA-S624 Amp - RF - R600x5 Front Speakers - RF - P165-SI + Alpine SPG-10C2 Rear Speakers - RF - P1650 Sub - RF - P2D4-10 on Vented Box
