blarg456 Posted July 30, 2018 Author Report Share Posted July 30, 2018 I checked with Mechman and they told me to run a wire from frame to engine where the alternator bracket is. Long story short I was able to route that cable through the load sensor on the ground wire and that seems to make everything work perfect. If I don't route that wire through the load sensor it seems to keep the truck in power saving mode because my voltage is only 12.8 when slamming the stereo. There is only 16.5-16.8 amps going through that wire and it doesn't fluctuate at all no matter how hard you push the stereo. With it going through the load sensor voltage is a solid 14.0-14.1 This also got rid of the Service 4WD message I was getting. Any ground loop noise I had is gone now. The only noise I have is a bit of alternator whine under the hood when it's charging but was told thats normal with the HO. Pretty happy now and no more stress from this. Now to add some more mid speakers and start saving for a 4 -15 wall build lol. I'll post some pics of my build when I get a chance. Thanks for the input and help. Link to comment Share on other sites More sharing options...
b2sdad Posted August 2, 2018 Report Share Posted August 2, 2018 What size cable were you able to fit inside that load sensor? I have some 0 gauge from Sky High all ready to go, but I don't think its going to fit? 2006 Nissan Titan Crew Cab XS Power D6500 up front, Mechman 270 amp alt, Front Stage:Hybrid Audio Legatia Tweeters and Midrange drivers in Custom A Pillars, HA Unity 6x9 inch Midbass in the doors, powered by an Arc Audio 1200.6 X2 and connected to a JL TWK 88 DSP Subwoofers: Four 8 inch Soundqubed Subs in a ported enclosure. Incriminator Audio 20.1 on the subs (@ 1ohm) Performance: JBA Headers, Uprev Tuned, Dynomax bullet muffler, 3 inch exhaust all the way back. Air raid CAI. Wheels: 18 inch Balistic Jester wheels on 33 inch Nitto TG2's Suspension: 6 inches of lift total. DK UCA's, DK LCA's, Icon coilovers up front, Bilstein Shocks in the rear with 4 inch blocks 2007 Chevy Suburban LTZ Engine: 5.3 DOD Delete, BTR Stage 4 truck Cam, TSP Headers, Gibson Catback exhaust. Tuned by Sam @ Advanced Modern Performance. Suspension: 2/4 Belkin drop. Belkin Sway bars, Spohn Panhard bar Audio: Pioneer 8400 NEX Head unit, Audio Dynamics DSP, 6th order enclosure with three 10 inch DC Audio Level 4s behind the third row. Wolfram 4500 on Subs, Wolfram AW 250.4 on the front stage Dual SkyHigh Car Audio 8 inch mid bass in the doors, quad 3.5 inch midrange drivers in the A-Pillars Dual Alternators, Mechman 320 powering a CES 40ah Lithium battery, OEM alt has an AGM on it.Viper remote start. Wheels: 24 inch Luxx wheels/ 305/40 R24 Grammatically speaking, Prolly is not a word. Link to comment Share on other sites More sharing options...
