puck_ya Posted July 14, 2018 Report Posted July 14, 2018 I designed 3 different ported enclosures for an Alpine Type R 12in SWR-2D (5th gen). I mostly listen to Hip Hop and EDM and run 1000W RMS to it. Designs are tuned approx. 30Hz, 32Hz, and 35Hz https://i.imgur.com/vdR9E7f.png
Triticum Agricolam Posted July 14, 2018 Report Posted July 14, 2018 The pink line (2.28 cu ft @ 29.9 Hz) would be my first choice. Keep in mind cabin gain is going to boost the low frequency output in your vehicle significantly, so the actual frequency response you get is going to look quite a bit different than what WinISD is showing you. Make sure you use enough port area, Alpine recommends ridiculously small amounts of port area for the subs, much to the detriment of their output. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
puck_ya Posted July 14, 2018 Author Report Posted July 14, 2018 59 minutes ago, Triticum Agricolam said: The pink line (2.28 cu ft @ 29.9 Hz) would be my first choice. Keep in mind cabin gain is going to boost the low frequency output in your vehicle significantly, so the actual frequency response you get is going to look quite a bit different than what WinISD is showing you. Make sure you use enough port area, Alpine recommends ridiculously small amounts of port area for the subs, much to the detriment of their output. After looking at some forums around here, I think I'll go with a 2.5cu @30Hz. WinISD Graph https://i.imgur.com/SbDZD0q.png Torres Specs https://i.imgur.com/EOHYG6S.png What the enclosure will look like. https://i.imgur.com/joIcTUM.png
Triticum Agricolam Posted July 14, 2018 Report Posted July 14, 2018 Yup, that should work well. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
