Dimensions Help
Still deciding on a sub box for my 1996 c1500 single cab after I installed bucket seats. After measuring it looks like my dimensions are: 30-33" long x 20" tall x 10-10 1/4" wide from arm rest to arm rest. I dont think a 12'" going to work unless I have the sub facing up towards roof or by the floorboard  space that almost seems to "flare" out about half way. Im not sure if I should downsize woofer size or what for the same output and ability to hit low in 30 hertz area. Kinda lost here since my 99-06 had more space between the seats. Any info on box help is appreciated, I was aiming for a box in the 2.5 cube area with an aeroport. Looking to throw 2-3000 rms at it. 2 brands in mind but I dont want to turn this into a VS thread. $200 difference, power difference is 2000 rms safely on one and 3000 rms safely on other sub.
Need subs. Not a VS thread, but different subs require different boxes.
Also, firing sub up should not be an issue. I'm assuming the top dimensions for this box will be 33"x20" max? If not, can you give us a quick sketch of the shape you're coming up with the dimensions labeled on the sketch? You can do it in crayons for all I care, just trying to understand what you're working with.
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
The attachment says it doesn't work bud, sorry
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Not sure if you know or not, but you will have to use a cloud hosted storage system to hyperlink images from for this forum. I use Photobucket.
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 1691 Guests (See full list)
