Pioneer TSW3003D4 Ported Box
vnisme
I was able to get these for 80 bucks at onlinecarstereo, and havent been able to find pricing like that since they came out.  So anyways, Pioneer recommends a 3 inch round port for 1 12".  Box will be for 2 12's, at 3.6-4 cu ft net @ 35hz, depending on port size.  Should I stay with the manufacture recommended specs or go for a 7.5 in round port?
3 cubic feet net with 50 square inches of port area. could be like this if it fits your space:
Power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Enclosure Specifications:
Fb = 35 Hz
Vb = 3 ft^3
External Height = 14.5 in
External Width = 33 in
External Depth = 19.25 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
* Wood Thickness is  3/4 for all Parts.
External Enclosure Parts:
Front = 28 1/4 x 13
Back = 33 x 13
Left & Right Sides:
Side 1 = 17 3/4 x 13
Side 2 = 18 1/2 x 13
Top & Bottom = 33 x 19 1/4
L Port Internal Assembly Parts:
Front to Back = 13 3/4 x 13
Extension = 10 7/8 x 13
Fb = 35 Hz
Vb = 3 ft^3
Port Width = 4 in
Cut Sheet List:
Front = 28 1/4 x 13
Back = 33 x 13
Left & Right Sides:
BassBox pro does not even support slot ports. In any case PM me with this just to not trash his thread.
  • Who's Online   0 Members, 0 Anonymous, 2384 Guests (See full list)
