Up first is a JL 300/2 amplifier. I've been running it on my front speakers for about 2 years, and every now and then one side will cut out. only does it every now and then. Would probably work fine bridged to a subwoofer.
Has a few cosmetic blemishes and one of the set screws are stripped(the one with the speaker wire, has a female plug on it). Also has a fin that has been broken off. (top left)
asking 100 dollars
Here is an Autotek 1200 SX amplifier. This one has went into protection mode, and i can't get it out. Probably just needs reset or whatever. Original box and manuals. Cosmeticly is a 10/10.
Model-SX 1200X
Power @ 14.4v
400x1@4ohm
700x1@2ohm
1200x1@1ohm
Signal to noise-80db
Freq. Resp.-10hx-500hz +1db
Crossover-Seperated low pass and subsonic
Lowpass@24db octave-35hz-250hz
Subsonic filter at 18db octave-15hz-35hz
Bass thrust at 42hz-0db to 18db
Input Sens.-0.2v-6.0v
Damping Factor-300 into 4 ohms
Power consumption-58 amps
Fuse Rating-60 amps
Dimensions- 10.4" wide, 2.5" high, 13.2" Long
asking 150
Here is an Autotek MX 12" sub. dual 2 ohm. cosmetics are 10/10. In perfect working order just like new.sealed and ported boxes are also available if needed.
Cheapest i found these were 150. I'll sell mine for 85.
# Power Handling - 600 Watts
# Dual Stacked 80 Oz Magnets
# 2.5" Black Anodized Voice Coil
# 40mm High Density Foam Surround for Nearly 2" Peak to Peak Excursion
# Winding Length 45 mm
# Silver Plated Push Terminals
# ADT Cone
# Chrome Steel Gasket
# Chrome Top & Back Plates
# Molded Dust Cap with Foil Logo Stamp
This topic is now closed to further replies.
