Hey guys looking for some creative ways to secure a single 10 enclosure in my trunk. Not looking to have anything that's a hassle or pain to remove. Just something that is fairly quick and easy if I need to remove the enclosure from the trunk for any reason. Thank you!
Velcro (the rough side) can stick to some carpets if you place enough on the under side of the box and set it against a wall.
Tie down straps can strap it into place
Bolts are the most secure but highly involved since you have to use the right materials so they dont rust then seal it up after your done / paint to prevent rust
Pressure fitting by cutting out spare pieces of mdf or birch to sorta jigsaw piece the enclosure into a certain space
A wedge thatd go under the box to lift it up at an angle and push it into a spot.
Velcro might be the easiest to do and is worth a shot. I think 3m has some good stuff
