Port size
06manvan
10 minutes ago, 06manvan said:
What length of 6" port I guess would be my next question?
26" long.
Or if you went with two 4" ports they would need to be 22" long.
Either option would tune you to about 34 hz.
Builds:
2 hours ago, 06manvan said:
Yeah. I messed up. Its 2.1 cubic feet. Deepest measurement is 24". What's my options after my screw up. Cubes seems a little on the small side
Do you have more space for a larger box?   After port displacement you are probably going to be around 1.7 cu ft and its going to be REALLY hard, if not impossible, to get a port long enough to get your tuning where you want it while having enough port area.
If it were me, I'd start over and build a slot ported box with the proper port area and tuning rather than finish a box that its likely will always have problems.
Builds:
58 minutes ago, 06manvan said:
I could, I can go deeper and taller. My problem with designing one with the calculators is I have a kerfed front. what should be a cubic feet and port length and diameter I should shoot for?
I can help you with a design, what sub are you running?
Builds:
do a 4" aero port, tune lower like 28-30hz. you'll have a wide playing range and get low.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   0 Members, 0 Anonymous, 762 Guests (See full list)
