sub box question for a newb on ported boxes
14 hours ago, sadams4431 said:
great suggestion never thought of that, would it need to be flared to reduce noise or would it be ok just cut to length and epoxied in ?
I would use a roundover bit on a router, if you have one available, to try and give it a bit of a flare.  If you can't do that at least try to break the sharp edge by hand.
looks like 7.5 or 9.5 is actual diameter i assume i should go with the 9.5   internal appears to be 7.25 on the 8 and 9.25 on the other
The 7.25 internal diameter tube may be just fine.  With either you are going to have to adjust the length of your port to get the tuning you want compared to an actual 8" internal diameter port.  If the 9.25 port will fit that would be great.  I'm just concerned it will have to be so much longer to get the tuning you want that it won't be practical.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 1117 Guests (See full list)
