Dual Amp input question.
So working out a build to start in a few days.
200amp alt, and good 1/0 ofc to the trunk, big 3 etc.
I am using a Deaf Bonce Machete MA-2000.1D for sub
And a 100x4 pioneer amp for doors.
The Machete amp will be wired at 1500w @ 2 ohm
Am I able to use the dual amp inputs to run 1/0ofc to it hooked into the machete amp, and then one coming out of the dual input to the pioneer 100x4 using a 1/0 to 4ga adapter.
I have heard a couple mixed opinions, but the 1/0ga ofc should be able to handle it (with the upgraded alt), and wouldn't the input then just act as a buss bar at that point?
I do a good bit of industrial electrical work for employment and am having a hard time seeing potential issues with this.
Good quality 1/0 is good enough for your 200A musical draw, the problem is you would need to give the main fuse a little more headroom due to the 4 channel on the same line and that's really not a good idea in terms of protection for daily driving, (e.g) rare but, you don't want a 200A dead short on a 250A fuse.
A small battery or some type of block/bar/distributor in the rear would allow you to fuse the amps independently.
  • Who's Online   0 Members, 0 Anonymous, 4882 Guests (See full list)
