Strapped amp question
Hey everyone. I have 2x audiopipe txx-bdc4 15s rated at 1400 watts rms on 2 strapped audiopipe apdli2000.1d amps 2000watt rms each
8 guage wires going from subs (series parallel 2ohm dvc = 2ohm total / as split final 1 ohm each) and a 6 guage from negative to negative on strapped amps. ( I had it laying around.) I notice master amp stays a bit cooler than the slave. The amp manual also states you should just the same gauge wire from negative to negative when strapping. Why? And could the bigger size be causing this effect?
Thanks a ton!
  • Who's Online   0 Members, 0 Anonymous, 3360 Guests (See full list)
