Second Skin Posted July 10, 2019 Report Posted July 10, 2019 A thick foil layer (not the Mylar thin foils being used by some) is what helps trap the vibration waves and proper butyl formula will turn those waves into low level heat waves. Using that foil-less butyl will just add weight to the metal and have minimal affect on the waves but will sound like it did something when you tap. Here is a chance to win some Damplifier Pro for free...just two easy steps Use a proper sound deadener instead of trying to piece materials together, it will be much better in the long run. Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use!
