neoM Posted August 7, 2019 Author Report Posted August 7, 2019 56 minutes ago, Joshdashef said: there is a guy on here named Triticum and he made an awesome calculator to help others decide how much port area they wanna go for, give it a shot. You don’t have to get optimal port area it’s just a recommendation to help you decide Thanks for tip
shredder2 Posted August 7, 2019 Report Posted August 7, 2019 I'd watch volume resizing the port, its going to change a bit unless you redo the enclosure, if you don't redo it it'll sure decrease volume unless its partially external. If the volume shrinks I'd lean towards the lower range of port I stated.
neoM Posted August 7, 2019 Author Report Posted August 7, 2019 1 hour ago, shredder2 said: I'd watch volume resizing the port, its going to change a bit unless you redo the enclosure, if you don't redo it it'll sure decrease volume unless its partially external. If the volume shrinks I'd lean towards the lower range of port I stated. Can you explain why exactly that port volume and why sticking with slot?
shredder2 Posted August 7, 2019 Report Posted August 7, 2019 2 hours ago, neoM said: Can you explain why exactly that port volume and why sticking with slot? I'll leave the explanation to others... an aero is more efficient yes. If you use an Aero I'd go with an 8" or dual 6" with actual flares. My explanation might be beyond my disabled ability to type. A slot needs more area due to the overall amount of wall surface contacting the airflow... hence the port size. With an Aero basically you can get by with less area due to the actual walls contacting the airflow being less with a round, add flares and it increases efficiency even more by smoothing the laminar airflow entering and exiting the port. Jeez... I hate typing on this phone
