neoM Posted August 6, 2019 Report Posted August 6, 2019 Hello, Im not so good with winisd or any other simulation program , as i dont really understand it at all . So im hoping someone have some spare minutes and can simulate a good box with aeroports for 1 SQ HDX315 D1. I have a box atm tuned to 32hz with slotport built by a friend of mine, but i want some little extra if possible? With this box i metered with termlab 144,9 with 1 extra XS D3100 and 1 gladen rc3200c1 @ .5 Thanks in advance and regards Andreas
Joshdashef Posted August 6, 2019 Report Posted August 6, 2019 What is your port area ? That seems super small for a 15 ? SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
neoM Posted August 6, 2019 Author Report Posted August 6, 2019 6 hours ago, Joshdashef said: What is your port area ? That seems super small for a 15 ? Really good question as my buddy didnt remember. I got the port out and took some pictures 39L x 10W x 20H
neoM Posted August 6, 2019 Author Report Posted August 6, 2019 57 minutes ago, shredder2 said: Those measurements are in cm? Yes it is
shredder2 Posted August 6, 2019 Report Posted August 6, 2019 How much power are you clamping and what is your net volume in Ft3 approximately? Basically you have a 7"x4" port then?.. 28ish in2? Usually a 15 on any power needs 50in2 plus of port.
neoM Posted August 7, 2019 Author Report Posted August 7, 2019 9 hours ago, shredder2 said: How much power are you clamping and what is your net volume in Ft3 approximately? Basically you have a 7"x4" port then?.. 28ish in2? Usually a 15 on any power needs 50in2 plus of port. Clamping 2,8kw-3kw . Net volume in Ft3 would be like 3.6 3.7ish . If i understand you right now, ur saying that i should have almost dobbel so big port as i have today?
shredder2 Posted August 7, 2019 Report Posted August 7, 2019 6 hours ago, neoM said: Clamping 2,8kw-3kw . Net volume in Ft3 would be like 3.6 3.7ish . If i understand you right now, ur saying that i should have almost dobbel so big port as i have today? Actually I'd probably go 60-65in2 of port in that volume. And that's sticking with a slot btw. Sorry man... if you're clamping 3k I'd definitely increase port area with that setup.
Joshdashef Posted August 7, 2019 Report Posted August 7, 2019 6 hours ago, neoM said: Clamping 2,8kw-3kw . Net volume in Ft3 would be like 3.6 3.7ish . If i understand you right now, ur saying that i should have almost dobbel so big port as i have today? there is a guy on here named Triticum and he made an awesome calculator to help others decide how much port area they wanna go for, give it a shot. You don’t have to get optimal port area it’s just a recommendation to help you decide SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
neoM Posted August 7, 2019 Author Report Posted August 7, 2019 53 minutes ago, shredder2 said: Actually I'd probably go 60-65in2 of port in that volume. And that's sticking with a slot btw. Sorry man... if you're clamping 3k I'd definitely increase port area with that setup. I will give it a try and see what im ending up with, my wooden hands are not the best out there so was hoping to do a new box with aeros. But sure im gonna give it a try! Thanks for all the help
