what is the smallest box i could use for 2 15 L7s
Vagabond
Hi Guys.....i have a soft top wrangler and want to build a sealed box with 2 15" L7s ....i want to know whats the smallest size i could build the box for them..
thanks
Jay
The smallest box is whatever is just physically big enough for the sub to fit into.  You probably won't like the performance much though.
With sealed boxes there isn't a hard cutoff where if you go lower than that the sub just stops working.  What happens is the smaller you go the more performance is going to degrade.  Its a gradual change, but at some point you will be better off to either on run one sub or run different subs all together.   Two 15" L7s are pretty big subs.  What are the dimensions of the space you have to work with?
Builds:
the measurements that i took out from kicker>com are tiny for the 1 15" L7..this are for a sealed box,
Model   Volume ft3    (L) Panel A in. (cm)   Panel B in. (cm)             Panel C in. (cm)
L7S15   2 (56.64)       16.5x16.5 (42x42)    16.5x15 (42x38.1)    15x15 (38.1x38.1)
PS>>>ill take measurements of the space i have today..
2 hours ago, Vagabond said:
ok so this is the space i have
42"w  x   23"H  x  20"D
You have PLENTY of room for a sealed box for those two subs.
Builds:
Ok cool at least i know i have enough space for eighter box ( sealed or ported)...now what you guys think would be the best way to go for me? Knowing i have a jeep wrangler soft top....i know i wount get that nice round solid bass since i lose alot of preasure.being a soft top...
Since you have the space, definitely ported.  You aren't going to have any cabin gain so a sealed box is going to fall on its face on the lower notes..
Builds:
  • Who's Online   0 Members, 0 Anonymous, 2979 Guests (See full list)
