ehall8702 Posted August 25, 2019 Author Report Posted August 25, 2019 So I went to put my new head unit in yesterday and all it does is boot loop, starts up, lights up and shuts off. I reset it and triple checked wiring but to no avail. My buddy felt bad cause it worked fine right up till uninstalling it, he just paid me for the install of his new unit. Luckily I found a factory reman unit ( same avh-x491bhs) for $190 so I just ordered it. Was also looking at a sph-da210 for same price but from what I read it was very apple friendly but not so much Android so I passed on it. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
ehall8702 Posted August 27, 2019 Author Report Posted August 27, 2019 Man I got sum tough luck! Place I ordered my new stereo from called and said they were out of stock! He offered me a avh-600ex , about the same as the 491bhs but a year newer. Doesn't have dual camera inputs ( which I planned on using) but has more compatibility with Android's so maybe it was a better choice. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
