Enlcosure design for 4 12s sealed
Ohmmm
The issue Im running into right now is port area.  Once I put those subs in and the power you plan to run thru them, it requires a LOT of port area.  Its eating up net volume quickly.
2 minutes ago, Ohmmm said:
4 doors and trunk have about 90sqft of deadener. What do you mean by sealing them?
If you want to significantly increase midbass response, you're going to want to seal off the large access hole in the interior door panel to turn the door cavity into what is essentially an enclosure.
This is what the difference would be between using that sub in a sealed box vs a ported box.  Definitely more output everywhere from 20 on up!  Any chance you have some room that we can make this box a bit bigger yet?
BYTizzle bit of a squeeze, eh? Verrrrry little increase in outside box dimensions is available. I'd say maybe an inch extra on width and depth without building it inside the trunk. If I did build it inside the trunk, which I'd rather not do, I have 41.5 inches of width well to well.
I even looked at "what if he ran 2 of their 12's instead", honestly made no difference.  They require a similar sized net volume as well.  Its a beefy sub and you plan to throw all the power at them which requires a good amount of port area.
With that program could I basically just enter butt loads of different tsp from different subs with the box specs that fit best for my trunk to find which sub is going to have the best all around output?
I was basing everything off subs and port on the same face.  Whether you want to fire it into the trunk or fire it into the cabin and seal it off, it will work eitherway
  • Who's Online   0 Members, 0 Anonymous, 2631 Guests (See full list)
