Surfer J Posted December 11, 2019 Author Report Share Posted December 11, 2019 I also had to fill in two of the screw holes. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
Surfer J Posted December 11, 2019 Author Report Share Posted December 11, 2019 After that I installed the bottom of the box. The first speaker baffle was next up. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
Surfer J Posted December 11, 2019 Author Report Share Posted December 11, 2019 Up next was the 45s in the corners of port. That is all for today. It doesn't look like I will be able to work on my box for the rest of the week. At work we are in the process of moving locations. My box and tools are at the new location. I got a text after I left work that I am needed at the old location the next two days. So it looks like my box is on hold until next week. Talk about bummed. I thought for sure my box would be completed on Friday. I will update as soon as I can get anything more done. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
Surfer J Posted December 12, 2019 Author Report Share Posted December 12, 2019 Well like I said yesterday there are no new updates on the build today. I won't be able to work on it again tomorrow and it is killing me. I would have been able to tell if it was all worth it. I truly hope It will be a noticeable difference. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
bmwking Posted December 13, 2019 Report Share Posted December 13, 2019 when you do the 2nd baffle, are you doing it full coverage and then using a flush bit on your router to make the port opening and sub hole? that'd be a good ideer Link to comment Share on other sites More sharing options...
Surfer J Posted December 15, 2019 Author Report Share Posted December 15, 2019 I do plan to round over the edges on the port opening. Also the second and third baffle layers will be a little wider than the first on. The first layer is in between the two side walls. The second and third will sit on top of the sides. Here is where I plan to round over the port ends. Here is the difference in the top baffles. The top image shows where the bottom baffle fits in between the sides. The bottom image shows where the second and third baffle will lay on top of the sides. I hope that clarifies for you what I intend to do and answers your questions. Thanks for following my build. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
Surfer J Posted December 16, 2019 Author Report Share Posted December 16, 2019 Hello everyone. Not much of an update today. I drilled the mounting holes in the top baffle and added the threaded inserts. I know what you are thinking "How were you able to fit all that into a single lunch hour?". Well it was tough and I had to work quickly. Seriously though I had to measure and remeasure because I laid out the mounting holes by hand. I didn't want to remove my sub just to mark out the mounting holes. Then remount it. Also I didn't take any photos. Seemed a bit too mundane to show off. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
Surfer J Posted December 17, 2019 Author Report Share Posted December 17, 2019 Just a small update today. I didn't have much time today to work on it. I was able to add the two main chamber braces. After I added the braces I realized I should have rounded over the top and bottom of the braces. I also glued together the top two baffle pieces. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
Surfer J Posted December 17, 2019 Author Report Share Posted December 17, 2019 As I was looking at the new braces and thinking about how I should have rounded them over, I realized I should have also rounded over the inside corners of the port. Below is what I am talking about. Oh well. Live and learn. I now have a lot of new ideas and plans for the next box I build. Next time I will be able to plan and build, hopefully, a much improved box. "A nod is just as good as a wink to a blind horse." Rolf - Ed, Edd, and Eddy Link to comment Share on other sites More sharing options...
YukonXL04 Posted December 18, 2019 Report Share Posted December 18, 2019 I was wondering with all the effort rounding the port entrance why you didnt do the corners... Sometimes you just forget lol. Your next box will be better hahaha Looking good though 18 Sierra 6.2 Z71 : 3 F8L's, DD M2a @.67, 1.95@33 05 TL build log SOLD 04 YukonXL : jvc kw-v51bt , RE 6.5c, 4 jbl gt5 12s, Memphis pr1000.1 5.5 cu.ft. sealed Link to comment Share on other sites More sharing options...
