2005 Tahoe - No Wall 161+ dB Daily (8 12s, 40kw, kick)
slapped the ZV515s back in the old 4 15 box, even though people said 3.1 cubes per sub would be too small
also sold one of my G30s (going to Cmax now), and found out one of my alts wasn't working.. still fixing that
lower power and more gainsssss
swapped out my G30 for 135ah Cmax
I did my measurements wrong and had to push the box 4" closer to the hatch:
port is about 4" from the hatch now, so I figured scores would drop, but they gained marginally
still dropping more than I'd like to, so I ordered more grounds and will be rebuilding my 2nd alt, along with raising voltage
also got to give some fun demos at a local get together today
it's funny how people flock to a vehicle that can demo more than 1 person at a time lol
dude ur building my dream ride lol i literally tonight ordered 2 Bass 30k's
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
320a Brand X Purple Metallic Ho Alt
125+ Ft of oversized 1/0
thanks :) it's turning into quite a crazy ride lol. never intended to put this much stuff in, or get this loud
I got some new numbers outta the thang
and new best clamp
the Cmax is really starting to bring the build alive. still dropping to 13.5v on burps, but holding 14s on music
and then, I've been running dual alts for months now.
finally bought an amperage clamp, went to test my alts awhile ago (this is when I had the 3 15s) and my one alt was not working
been going back and forth with Jon @ Brand X for what feels like months now, and I cannot figure it out.
I was told it was a regulator issue, so I bought a new one and replaced it:
still didn't fix the issue
swapped which alternator was where on the bracket (in case it was a ground issue) still nothing. swapped diodes. swapped power and ground. nothing.
got the Brand X Electrical voltage knob (which works great):
but that 1 alt still wouldn't do anything
so I took it off and went back to the OEM alt, and 1 270a
this will allow me to go back to charging closer to 16v
also added some more (crappy) grounds to the 2 already (crappy) grounds I had
just 4 runs to 2 of the seat bolts
bought the wire to run dedicated runs from the alts, just need to find time
man im lovin this build!!!!! lol its legit what im working on right now, gathering all my stuff. im using brand x alt also, just got my knob today. some stuff going into camry, but big build is in a tahoe this summer after i got everything. even got a 135ah cmax waiting to get here. how do u like it? after u charged 15.5 where u still dipping that  low like before?
ordered this stuff today, https://fulltiltaudio.net/collections/custom-metalworks/products/inputs
https://fulltiltaudio.net/collections/custom-metalworks/products/quad-alternator-lugs
figure i share with ya, was a good find. local michigan also.
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
I LOVE the Cmax. Tobbie and Mike @ Coventry were fantastic to me, and my voltage is much better.
I ended up clamping about 6kw more by swapping from 2 G30s to the 135ah cmax, and about 10kw more from 1 g30 to the 135ah cmax
here's the last video of the truck before yet another rebuild
got bored, did some theorycrafting, had Correy build me two new boxes that I'll pick up tomorrow
left box is a Bassahaulic, Drew Jones design - 12 cubes, 270 square inches of port, tuned @ 38z
right box is very similar to my current one, again designed by me - 11.67 cubes, 314 square inches of port, tuned @ 45hz
I better get a 160 on the dash out of one of these..
loaded up the new box with some ZV15s
d0.7, 4 layer coil, mega roll v2 surround, progressive spiders
wired @ 0.35 and clamping like 20kw, the best I did was a 158. I was NOT a fan of this sub build.
swapped back for my SPL ZV5s (8 layer coil, spl surround, black spiders)
wired back @ 0.5, clamping 17kw and did a 158.66 on the dash as the best
this was the last video I got before my amp went up in flames
about 3 burps later, boom - smoke and flames
clipping was most likely the culprit. I was pushing HARD to try for a 159 on the dash
gonna send it to Mark Cannady to rebuild, and he's going to add a clip light indicator so it won't happen in the future
