I bought these mids around January for a project that never happened. Only 2 of them have seen power and they were paralleled on a single HT channel that does 20w at 8 ohm so the 2 that have seen less than 10 watts. I have 2 that are still sealed in the box. Looking to get $25 per mid shipped
Excellent quality bass-midrange for two way systems or mini sub
Use at home or in the car
1" high temperature voice coil
Pulp cone with rubber surround
Vented pole
Up to 100 watts RMS power handling
Sensitivity - 89db (2.83 volts)
Impedance - 4 Ohm (SVC)
here are some pics
T/S Parameters
Fs = 62.2 Hz
Re = 3.4 Ohms
Qes = 0.68
Qms = 5.69
Qts = 0.61
Mms = 19.1 g
Rms = 1.31 kg/s
Cms = 0.342 mm/N
VAS = 6.6 litres
Sd = 116.9 cm2
Xmax = 5.5 mm
DC.jpgDC POWER
how much for all 4 stephen?? could use this in the F-150.
ill pm you.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
This topic is now closed to further replies.
