Ray Posted May 9, 2008 Report Posted May 9, 2008 I want everyones input Where does the port start and stop??? Say each panel or "baffle" is 15" long, how long is the port? What if there were 4 subs instead of just 2, there were 2 more on that second angle. Ive been frying my brain with this for a few days now. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Boon Posted May 10, 2008 Report Posted May 10, 2008 You could look at it 2 ways. Either you could say the second angle counts as free space (especially if it had subs on it) or you could say that the second angle was 'flare' in which case I would work it out as if it was a giant Aeroport - which means you calculate it as 'half the flare belongs to the port' - so you measure half the length of the flare and add it to the port length, and calculate as if it was all the same width. 10.x volts fo' life!
