Izzyman Posted March 17, 2020 Report Posted March 17, 2020 So using stock head unit on Dodge Journey. I have tried two different line output converters and both are only putting out 0.4 Volts. (levels turned to max) I thought this was supposed to be closer to 2-5 volts. Is this a problem? Is my amp getting enough signal? Is this something I should worry about? Thanks,
reedal Posted March 17, 2020 Report Posted March 17, 2020 What are you using as a signal to measure? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Izzyman Posted March 17, 2020 Author Report Posted March 17, 2020 3 minutes ago, reedal said: What are you using as a signal to measure? a multimeter
reedal Posted March 17, 2020 Report Posted March 17, 2020 No, I mean what is your signal source? Music or tone? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted March 18, 2020 Report Posted March 18, 2020 At what offset? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Izzyman Posted March 18, 2020 Author Report Posted March 18, 2020 2 hours ago, reedal said: At what offset? No idea?
reedal Posted March 18, 2020 Report Posted March 18, 2020 That could very well be the problem then, though not knowing what LOC you are using, it could also be that. https://www.dropbox.com/sh/qm8w9d5ydn0ucdt/Pzr8B6LlYw/Snow's DD-1 Tracks.zip You can find a 40hz -0dB track there. As for line out converters, most a junk, poor quality, and will create distortion in your signal. Rockford might still offer one, otherwise I'd recommend audiocontrol if quality is important to you SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Izzyman Posted March 18, 2020 Author Report Posted March 18, 2020 32 minutes ago, reedal said: audiocontrol This one?https://www.newegg.com/p/0HF-006S-00032?item=9SIA0WYB132605&source=region&nm_mc=knc-googlemkp-pc&cm_mmc=knc-googlemkp-pc-_-pla-carcandy-_-car+amplifiers-_-9SIA0WYB132605&gclid=Cj0KCQjwjcfzBRCHARIsAO-1_OpnoT5gQNehq2j6zuM8MC4YrvQLlIi1zMRqhUiKeChO2XzYWPA0w1MaAkfFEALw_wcB&gclsrc=aw.ds
reedal Posted March 18, 2020 Report Posted March 18, 2020 If all you need is two channels, then yes. They have larger models if you require more channels. If you're just adding a sub stage though, that one will be perfect SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
