What would cause you worries with your set up? Just make sure your gain isn’t past the halfway point. Depending on the voltage of your head units pre outs is where you set your gain of course. If your head units pre outs are 5 volt pre outs then turn the gain on all the amps to 1/3 (10 o’clock) of the way. If the pre outs on your head unit are 4 volts turn the gain on all the amps to a little less than 1/2 (11 o’clock) of the way. And if your pre outs on your head unit are 2.5 volts then turn the gains to 3/4 (2 o’clock) of the way. And to be honest with you, if your head unit/stereo is only producing 2.5 volts per pre out then the head unit isn’t that good anywhere else either and you should get a different one. But most likely you are running a good stereo with 4 volt or 5 volt pre outs.
:guido:
  • Who's Online   1 Member, 0 Anonymous, 358 Guests (See full list)
