4th order design help
lj7802
im building a 4th order bandpass 1ST one im using Alpine Type-R 12"  (R-W12D4) hoping to get some feedback on the design i came up with any changes i should make any help i can get would be much apreaciated. the port dimensions are 4.5" x 16" and the length is 6" with baskets/magnent in the ported chamber .
With 4th order enclosures, the port area is suppose to around half the total cone area of the subwoofers and closest to a square as you can get it. A rectangle will be ok but not as rectangular as you have it. Slots don’t work as well as squares with 4th order enclosures.
:guido:
27 minutes ago, lj7802 said:
51Hz with 72sq in, port area and just under 15sq in, port area per foot is what i came up with, first 4th order box but im pretty sure im doing it right
You’re using the wrong science for designing a 4th order. The port area has nothing to do with any of the chamber sizes, just the subwoofer size(s).
:guido:
  • Who's Online   1 Member, 0 Anonymous, 717 Guests (See full list)
