Hello, so I will be applying some 80 mil sound deadener(probably 90%+ coverage probably of kilmat or noico) to the outer and inner skins of my doors. Is there another product that you would recommend applying to the inner skin atop the deadener or inside the door panel? Didn't know if there is much of anything else to help with noise attenuation/quieting(which my suburban definitely needs lol, and insulative properties wouldn't hurt either) that is typically recommended? If so, how much do you think it would help over just the deadener? Also, looking to go for a low buck solution if there is one... kind of like using the kilmat/noico vs dynamat or something. Would also prefer it to be simple and easy to apply, unless something just works that much better or is at a much lower price point. Thanks everyone.
Either Luxury Liner Pro Mass Loaded Vinyl with Closed Cell Infused or Mega Zorbe HMF for the outer skin and OverKill/OverKill Pro for the inner skin between the door panel and and skin.
Here is an article on Door Skins: https://www.secondskinaudio.com/sound-deadening/car-door-insulation-for-best-car-audio/
If you are looking to increase your door mid bass performance, check out this video:
