Audio Dynamics ADDSP46
Hey there guys, I was curious if anyone here has messed around with the new Audio Dynamics DSP yet?  I looking to build an active three way setup for my suburban with AD Components. The only thing that was confusing to me according to the Audio Dynamics website are the inputs? There are only two rca inputs? I have access to a four and six channel amp not sure how to make the proper connections. Any ideas?
2006 Nissan Titan Crew Cab
XS Power D6500 up front, Mechman 270 amp alt,
Front Stage:Hybrid Audio Legatia Tweeters and Midrange drivers in Custom A Pillars, HA Unity 6x9 inch Midbass in the doors, powered by an Arc Audio 1200.6 X2 and connected to a JL TWK 88 DSP
Subwoofers: Four 8 inch Soundqubed Subs in a ported enclosure. Incriminator Audio 20.1 on the subs (@ 1ohm)
Performance: JBA Headers, Uprev Tuned, Dynomax bullet muffler, 3 inch exhaust all the way back. Air raid CAI.
Wheels: 18 inch Balistic Jester wheels on 33 inch Nitto TG2's
Suspension: 6 inches of lift total. DK UCA's, DK LCA's, Icon coilovers up front, Bilstein Shocks in the rear with 4 inch blocks
2007 Chevy Suburban LTZ
Engine: 5.3 DOD Delete, BTR Stage 4 truck Cam, TSP Headers, Gibson Catback exhaust. Tuned by Sam @ Advanced Modern Performance.
Suspension: 2/4 Belkin drop. Belkin Sway bars, Spohn Panhard bar
Audio: Pioneer 8400 NEX Head unit, Audio Dynamics DSP, 6th order enclosure with three 10 inch DC Audio Level 4s behind the third row. Wolfram 4500 on Subs, Wolfram AW 250.4 on the front stage Dual SkyHigh Car Audio 8 inch mid bass in the doors, quad 3.5 inch midrange drivers in the A-Pillars
Dual Alternators, Mechman 320 powering a CES 40ah Lithium battery, OEM alt has an AGM on it.Viper remote start.
Wheels:  24 inch Luxx wheels/ 305/40 R24
Grammatically speaking, Prolly is not a word.
  • 3 weeks later...
I looked at them as well, 2 RCA inputs or 4 speaker level inputs, so if you use RCA you get a Left and Right input no fade control (who uses that anymore) you can have 6 RCA outputs to do whatever you want to with. You can run 6 channels of subs, midbass, midrange, or tweeters or any combination you want. each channel does what you program it to do. Also does each channel level control and timing. More than a plenty in the EQ as well. 4v outputs
  • 1 month later...
I though that could be done, I appreciate the input Sir!
  • 3 months later...
For anyone who happens to read this thread in the future, be aware that the ADDSP46 requires both normal and bass signal from your aftermarket head unit.  Which means Y-adapters from each front channel and each bass channel into the two RCA inputs.
The input max on the ADDSP46 is 2.5v.  You should experiment with volume levels and a DMM to find the max volume for the DSP.
  • 3 months later...
Appreciate the insight Sir, I just checked on the Pioneer website and it says I have 4 volt preouts, is that going to be an issue since the AD DSP has a max of 2.5v? If so how do I get around this?
  • Who's Online   0 Members, 0 Anonymous, 1114 Guests (See full list)
