Hi I am new to car audio and I am planning on running three 10inch DC level 1 m4 and I don't k ow what would be better the duel 2ohm or the duel 4ohm. Would appreciate the help.
If you’re gonna run a 1 ohm amp then get 3 dual 2 ohm subs wired in series to 1.33 ohms. But if you’re gonna run a 2 ohm amp then get 3 dual 4 ohm subs wired in series to 2.67 ohms. Unless you want to run a good 1 ohm stable amp under 1 ohm then get 3 dual 4 ohm subs wired in parallel to 0.67 ohm. So really it depends on the amp you’re gonna run.
:guido:
