Help for Blow thru for 2 13.5 jl audio W7
Just wondering if anyone could help with a design for a blow thru on 2 13.5 W7 on a single cab 2009 GMC Sierra
I’ve never done a blow thru
And also the jl audio specs for the sub enclosure honestly seem very small has anyone ever done boxes that are bigger than the recommendations?
i personally would like something like in this video what do you guys think?
thanks in advance any information helps
Do you have a cap or cover for the bed of that truck? If not then there’s no way to do this. The guy in the video usually has a cover or cap over his bed because rain would get into the rear chamber’s port. There’s a way around that though. You can do a 4th order enclosure instead of a 6th order enclosure like in the video. It will still be a blow through. If you have no cap or cover for your bed then you can use marine grade plywood to build the enclosure so weather won’t fugh it as bad. But it’s smart to at least get a sleek cover because you don’t wanna take any chances of the weather messing it up and plus you don’t want people to have easy access to your set up.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 392 Guests (See full list)
