Qtc formula confusion
RazorRust
I am trying to build a subwoofer box.
My understanding of Qtc is that below 0.7 is overdamped and above 0.7 is underdamped. Overdamped will be a tighter bass.
However, when I enter a subwoofer's Vas, Qts, and a Vb (box volume) into a Qtc formula, I get a lower Qtc with a larger box. Which will not provide a tighter bass.
So what am I doing wrong?
Smaller enclosures are more responsive and can handle more rms. But if done correctly a bigger enclosure can have good response and accuracy and get louder than a smaller enclosure. You just have to tune the enclosure lower if you increase the enclosure’s net volume. Plus the port area has to be done accordingly. Just let me know.
:guido:
I'm just using different Speaker box calculators I've found online. They all give me the same results. Like this one, https://www.diyaudioandvideo.com/Calculator/SpeakerBoxEnclosure/ .
I definitely want a sealed enclosure with a fast response ("tighter" bass as some say).
Its going in a hatchback car. I've got 300w rms for the subwoofer. I was trying to decide between 2 8's and 1 10. I started looking at subwoofers and boxes available. I was entering the qts, vas, fs, and vb into these speaker box calculators trying to find a decent set up.
I read a lower qtc was overdamped and higher was underdamped. I believe anything around 0.6 - 0.9 qtc is going to sound good. I would prefer a tighter bass.
I was confused because in my head a larger sealed box would seem underdamped (not as tight), but I guess this is not the case.
There isn’t an average sizing rule when it comes to subwoofers because if the difference is t/s parameters and specifications each subwoofer has. But no worries. What are your choices, like which 2 8” subwoofers and which 10” subwoofer are you planning on choosing from? Once you tell me, I can tell you what size enclosure to do on either to achieve tight and accurate bass.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 599 Guests (See full list)
