On 4/10/2022 at 4:21 PM, killerc998 said:
Decided to do front batteries delete. Use a Jim's Machineworx fuse block.  Voltage is 14.5/8 at idle. Full till it drops a volt. Got 40 more headway lifepo4. Going to add and have a total  144Ah.  All that wire. 2 runs of 2/0 welding wire from 270alt, 1 run 1/0 from 145alt to fuse block. 2 runs 2/0 to battery, one run 1/0 to the air compressors and mid/high amp. IMG_20220409_134844663_HDR.thumb.jpg.f4452e9e362d1ee3dbd0028cc3d5f027.jpg
Went and got two of those type of fuse blocks after seeing this post, I didn't even know he had some made. I was going to go the SMD route but already had some of Jims stuff in the ride.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
