Sub not hitting high frequencies Well
Ive got a skar evl 18 Dvc 4 ohm in a custom designed box tuned for 32hz powered by a skar rp2000 watt amp and a pioneer fh-s722bs headunit. The amp bass boost is on 0, gain half way, subsonic filter set close to 32hz. The headunits setting are untouched other than the crossover and slope for sub. When the crossover is set to anything above 31.5 hz and volume is way up the sub makes an awful noise on the higher frequency notes. Set to 31.5 hz it plays the lows like a champ though. Maybe someone can help me figure out where im going wrong.
What frequencies are you trying to hit with the sub? 32 hz tuning will probably roll off at 55-60hz and anything above that let the mids do their job
Team MaxRetribution
Si Vis Pacem Parabellum
  • Who's Online   0 Members, 0 Anonymous, 377 Guests (See full list)
