Deaf Bounce vs. Resilient Sounds
12 A6
Looking for a 2400 to 3000 rms single 15. These 3 made my short list - Resilient Onyx, Deaf Bonce DB-SA415 Street and Deaf Bonce DB-3015. Unfortunately I haven't heard any of them in person so obviously I'm having problems. Any advice or recommendations would be appreciated! Will be running a Taramps Smart 3.
The DB Sa4 is the king of that bunch. They're beastly and play lows like a mother fker if your build is on point. I'd go DB4 out of all of those
Team MaxRetribution
Si Vis Pacem Parabellum
It depends on what you are aiming for with your build. I've had a very similar comparison recently, a single RS Onyx 12" vs a single DB SA312, same box. If you're looking for numbers then I believe the RS is your better bet with 4" VC and an FS of like 41hz. For music the DB had a larger coil gap to allow more non-linear movement, which is more forgiving when smashing below 32hz. The DB did hit deeper, but seemed to lack motor force compared to the Onyx.
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
