Help! Which setup is better?
Hi guys, lurker seeking advice. I have two setups for my car (1996 Impala SS with 200 amp alternator):
(2) Audiopipe TXX-BDC2-15
(1) 8 in port tuned to 36Hz
5.5 cu ft. total after sub displacement and port
or
(2) Audiopipe TXX-BDC4-12
(2) 4 in ports tuned to 30Hz
2.8 cu ft. per chamber
I have two sub amps to choose from:
Taramps MD1800.1
Bully Slayer 3000
Which would be the better setup for my ride?
1 hour ago, rcollins said:
Hi guys, lurker seeking advice. I have two setup for my car (1996 Impala SS with 200 amp alternator):
or
Taramps MD1800.1
Bully Slayer 3000
The BDC4 is 1100w rms? I don’t think the taramps 1800 would power 2 very well, just my opinion. Consider box rise, and you’d get something like 600-700w per sub at best?
4 minutes ago, JakeW said:
The BDC4 is 1100w rms? I don’t think the taramps 1800 would power 2 very well, just my opinion. Consider box rise, and you’d get something like 600-700w per sub at best? And the “bully slayer” puts out 3000w at 1ohm, so good luck doing that for 2 2ohm subs...
Thanks for the reply. The BDC4s I have are dual 4 ohms, so I can wire them down to 1 ohm. I know that I wouldn't see 3000 rms from the Bully amp due to box rise and my alternator output.  I'm  just looking for suggestions on the better setup or any suggestions using this equipment.
  • rcollins changed the title to Help! Which setup is better?
  • Who's Online   0 Members, 0 Anonymous, 1005 Guests (See full list)
