okay i have an enclosure with the demensions: I need to know how big to make the port.. it is a sealed enclosure and i want to port it.. it is for 2 12" woofers...
and please let me know how many cubic ft it is :)
10.5 Width
30.5 Length
16.5 Height
the enclosure is a funny shape.. so it is a little over them dimensions.. but they are close to then...
i was going to make my own port 2" Wide and go down 12" and go 12" deep into the enclosure so it is a rectangle port right in the front of the enclosure..
IM A LOW LIFE SCAMMER SO I WAS BANT....TEH HAMMA is NOT my friend
START NAMING YOUR TOPICS...NOT JUST HELP!!!!
ARG
NoFearX18 said:
trainman0978 said:
Depending on subs trying to port that box is useless. Its 2.0 ft^3 sealed. 2ft^3 is the usually the volume for ONE sub ported, usually. What brand and model are the subs?
Edited by duct_tape123
i am going with 2 kicker CVR's DVC..
like i said the enclosure is a funny shape.. it is over 2 cu ft.. i will take sopme pics of it real quick so you can see what i am sayin..
Is it a wedge shape? Deeper at the bottom than the top? The CVR12"s need minimum of 1.75ft^3 + port displacement (quoted from their manual). That box would be good for 1 of them ported, but not 2. For 2 you would need MINIMUM 3.5ft^3 + port displacement.
i have my pictures uploading to my photobucket account.. so... stick with me for a second.. and you will see!!!
picture of the back of the enclosure
picture of the top.. at an angle...
picture of the enclosure straight looking foward..
i was going to use my straight edge and go from top of the sub to the other and make a line.. then do the same on the bottom.. then in the center of theenclosure in all that dead space, i was going to put it right in the middle.. and cut a slit in it.. and then built the port..
At the most that box is 3ft^3. If you want ported you should build a new box that is as deep as one of the corners all the way across. How deep is the box at one of the front corners?
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
