 So just a general knowledge question i would guess. Right now i have single run of 1/0 +an - running from under hood battery to battery in trunk. 2 runs of 1/0 from alternator to front battery. All 1/0 grounds under hood. would it make a difference running the positive to rear battery from the alternator as well as ground or do i have it correct already? have d3400 xs power under hood and d3100 in the trunk. Running American Bass 120.1 sub amp on American bass HD12 . Skar 400.4 on set of Skar  SPX 6.5 components and 4 Skar FSX 6.5 mids.
I would do at least 1 more run between batteries, if not 2. What size alternator are you running?
As long as you've done the big 3 upgrade, seems fine. You wouldn't benefit from splitting the alternator runs to each battery. If you hook your batteries up in parallel, it essentially becomes one battery. But to move electricity more fluidly between the batteries, I'd add a run or 2
OK wasnt sure if it made a difference or not going to be going to lithium in trunk as well and hope i can get a second run through firewall kinda tight with just 1 may have to go under car with them
. Thank you for your input greatly appreciated
