Need help wiring new door panels
Hey yall, i have always used this site to learn about car audio and finally need some help with my custom door panels i just got made. So each door has 4 8" mids and 4 tweeters. I have not bought a amp, speakers or anything yet and before i do i want some insight on how to wire them and the best way to do this. So far all i know is i need to get 4 8ohm 8" mids for each door wired in parallel which is 2ohm in the end? Or is there a better way to wire the mids?  I also do not know how i should wire the tweeters. I was looking at the Cresendo 2000rms 4 channel to go with my Bassclef 6k i have for my subs. All the insight how to wire my door panels would be great! thank you
So, I'm doing sort of the same thing. 8 8's and 8 tweets. The only difference is I'm going to run the 8's off the C2000.4d, 4 ohm per channel and then the tweets off my S4, 2 ohm per channel.
I don't see any reason you can't run 4 8's on channel 1 and 2 at 2 ohm with a band pass crossover, then the tweeters off 3 and 4. That should work fine. Best case scenario is use a DSP I would say.
So im thinkin the same thing run my mids off the 2000.4 and my tweeters on another amp. I am looking at the PRV MR500 neo. They are rated 250rms each. I am thinking wire 2 8s in parallel to 1 channel at 500rms at 2ohm. Read up its better to wire 2 8" then 4 8" in parallel?
If you use 1 amp, then you'll need 8 ohm speakers to drop down to 2 ohm, 4 8's per channel. If you use an amp for the speakers, an amp for the tweeters, then you could get 4 ohm to wire down to 2 ohm. 2 8's per channel. It's really up to you. Save yourself some money and run 1 amp, or run 2 amps and get a full 250 watts per 8. Either way it'll be loud! If you run 1 amp though, you'd need some pretty hefty tweeters to handle all that power.
For the RCA's, there's a couple solutions. You could run RCA splitters from your original set of RCA's
https://skyhighcaraudio.com/sky-high-car-audio-premium-y-splitter/
Also you could use an RCA distribution box
https://skyhighcaraudio.com/shca-clear-1-to-3-rca-distribution-block/
Or, some amplifiers actually have an RCA out so you can just use that to jump to the next amp.
Or, one of my favorite things in my truck.
https://skyhighcaraudio.com/three-2/
