Jamster Posted May 30, 2021 Report Posted May 30, 2021 I have recently bought 2 skar audio svr-12s that run about 800 watts each and im going to be hooking it up to a 3500 watt amp. Before I install my new subs I wanted to upgrade my battery. I have a 2005 nissan altima and it uses a 24f battery. I dont really know much about the batteries but I have been having trouble finding a a good strong battery that will fit my car. Any help would be greatly appreciated.
Dafaseles Posted May 30, 2021 Report Posted May 30, 2021 1 hour ago, Jamster said: I have recently bought 2 skar audio svr-12s that run about 800 watts each and im going to be hooking it up to a 3500 watt amp. Before I install my new subs I wanted to upgrade my battery. I have a 2005 nissan altima and it uses a 24f battery. I dont really know much about the batteries but I have been having trouble finding a a good strong battery that will fit my car. Any help would be greatly appreciated. If you can't find a strong AGM to go under your hood, you can always add a second in the trunk. Or you can go lithium. In my opinion, they're better than AGM and you can run more watts off lithium while still using the stock alternator. You could also look into running a super cap bank. You can run those with a regular battery and not have too many issues. Make sure before you do anything to do the big 3 upgrade. That's huge 2011 Chevy Silverado under construction My build log here. Check it out!
Jamster Posted May 31, 2021 Author Report Posted May 31, 2021 19 hours ago, Dafaseles said: If you can't find a strong AGM to go under your hood, you can always add a second in the trunk. Or you can go lithium. In my opinion, they're better than AGM and you can run more watts off lithium while still using the stock alternator. You could also look into running a super cap bank. You can run those with a regular battery and not have too many issues. Make sure before you do anything to do the big 3 upgrade. That's huge I wasn't looking for anything specific when it comes to the battery. I also heard that if I add another battery at some point, its better for me to add the same battery that im using. I already have an upgraded amp and I have the big 3 upgrade as well. For the battery I was just trying to find something that can handle my build without adding a second battery, but Im willing to if I have to.
Dafaseles Posted May 31, 2021 Report Posted May 31, 2021 Well, in my opinion, 3500 watts is quite a bit for stock electrical. You'll need 2 batteries. Or just 1 lithium, though you can't put lithium under the hood. You'd have to do a battery delete under the hood and put the lithium somewhere else. And you can mix battery sizes and brand, but you don't want to mix battery chemistries. Lead acid with lead acid, AGM with AGM, Lithium with Lithium 2011 Chevy Silverado under construction My build log here. Check it out!
