American bass vfl 500.4
Gbaker
RMS power @ 4 Ohms: 250 Watts x 4.
Max power @ 2 Ohms: 500 Watts x 4.
American Bass is well-known for the quality of its speakers, but it also makes outstanding components that are easy to mount.
The weight of the mount is less than 12 lbs, which means you can use a smaller mounting plane. This means that you do not have to bolt down a 3/4-inch thick sheet of plywood across the width of your trunk space. Rather, it should be set off to one side and used with an even thinner sheet.
  • Who's Online   2 Members, 0 Anonymous, 745 Guests (See full list)
