Apollonick Posted November 6, 2021 Report Posted November 6, 2021 I have a quick question if anyone can answer it ? So I have a sae2000d with 2 sets of terminals with 2 sa12 dvc 4 subs wired separately. Right now separate they are at 2 ohm but can be wired together for final one ohm or if I wire each separate with the sets of output terminals will the amp do it for me.
Dafaseles Posted November 6, 2021 Report Posted November 6, 2021 If each set of wires coming from each sub reads 2 ohm, the amp will see 1 ohm. That's perfectly fine. Even though it has 2 sets of speaker inputs, they are connected internally, so it's still a single channel amplifier. There are 2 sets for ease of installation. Nothing more. If you wire the subs together to get a final 1 ohm impedance for both, and only connect the 1 set of speaker wires, it'll be the same outcome. Either or. It's up to you 2011 Chevy Silverado under construction My build log here. Check it out!
