So over the past couple months ive been having an issue with my system that has gotten worse but i cant find the cause of it. When i get in my car and drive, i have no issues. but as soon as i park and listen at a low volume for a 10 minutes or so my volume will start going quiet for a few seconds, then it will come back. my sub and my doors do this. they are both amped, and both ran through the skar eq. I have checked all my power/grounds and nothing is loose so my only thought is my rcas which i got new when i got my eq right after this issue started happening, so maybe its the headunit? i dont know, but if anyone has any ideas please drop them.
I attatched a video showing what im talking about,
ELECTRICAL:
Mechman 240a
190ah AGM
Big 4 SHCA 1/0 OFC
1/0 SHCA CCA
4ga SHCA OFC
FRONT STAGE:
Sundown SAEv3 400.4
1x Skar NPX 6.5 per door
1x Skar VX1 Super tweeter per A-Pillar
Skar 7 Band EQ
SUB STAGE:
JP23 @ 1 ohm
Sundown Xv3 15
By parked, do you mean with the car still on? Or with the car off?
Car still running, and when it happens my voltage does not drop.
ELECTRICAL:
Mechman 240a
190ah AGM
Big 4 SHCA 1/0 OFC
1/0 SHCA CCA
4ga SHCA OFC
FRONT STAGE:
Sundown SAEv3 400.4
Skar 7 Band EQ
SUB STAGE:
JP23 @ 1 ohm
Sundown Xv3 15
If it doesn't drop, where are you measuring it from?
And what kind of car is it?
reading the voltage from the bass knob included with the D4S JP23, so voltage at the amp. this is in a 2008 scion xb
ELECTRICAL:
Mechman 240a
190ah AGM
Big 4 SHCA 1/0 OFC
1/0 SHCA CCA
4ga SHCA OFC
FRONT STAGE:
Sundown SAEv3 400.4
Skar 7 Band EQ
SUB STAGE:
JP23 @ 1 ohm
Sundown Xv3 15
2 minutes ago, Dafaseles said:
Does that car have any type of ECU regulated voltage controller?
Ive read that it does, 13.6 after it warms up but ive seen 14.2 on startup. it didn't start doing this until i amped my doors, but it used to be only my doors that did it, now it is the sub and doors both. I believe it is an rca issue of some type but im not 100%
ELECTRICAL:
Mechman 240a
190ah AGM
Big 4 SHCA 1/0 OFC
1/0 SHCA CCA
4ga SHCA OFC
FRONT STAGE:
Sundown SAEv3 400.4
Skar 7 Band EQ
SUB STAGE:
JP23 @ 1 ohm
Sundown Xv3 15
Do you have 1 set of RCA's going to the back then split between the 2 amps? Or a dedicated set to the 4 channel and another dedicated set to the sub amp? I can't remember if that had unit has multiple RCA outs
i have a set running from the front channel on the headunit to the main input on my eq, then from the eq i have 2 sets for the 4 channel and 1 for the bass amp. gonna go out and try switching the main input from the front to the rear channel and see if its my headunit preouts causing the issue
ELECTRICAL:
Mechman 240a
190ah AGM
Big 4 SHCA 1/0 OFC
1/0 SHCA CCA
4ga SHCA OFC
FRONT STAGE:
Sundown SAEv3 400.4
Skar 7 Band EQ
SUB STAGE:
JP23 @ 1 ohm
Sundown Xv3 15
there is a front, rear, and sub output on my headunit though
ELECTRICAL:
Mechman 240a
190ah AGM
Big 4 SHCA 1/0 OFC
1/0 SHCA CCA
4ga SHCA OFC
FRONT STAGE:
Sundown SAEv3 400.4
Skar 7 Band EQ
SUB STAGE:
JP23 @ 1 ohm
Sundown Xv3 15
