Superkushmaster Posted March 23, 2022 Report Posted March 23, 2022 Bought at ar1.8000 sound stream not too long ago abs can’t get the mf to work. I had it wired up and everything but I’ve never gotten it to turn on. I’ve checked the voltage on my remote wire and it has a change when the radio turns on so leads me to believe my amp is shot. Is there any way I could test my amp and see if it works with some digital reader or am I just s.o.l any advice helps cheers
SnowDrifter Posted March 23, 2022 Report Posted March 23, 2022 I know ya said you checked it with a multi meter, but could we get some hard numbers? The measurements I want are: - DC voltage at the set-screws when measured across + and - - DC voltage at the set-screws when measured across turn-on and - ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
