Enclosure design help for Tang Band W5-1138SM
trm122
I have a couple of these 5.25" subs that were originally going into the front door OEM enclosures of a 996 Porsche.  I've decided to keep the OEM woofers in the doors and utilize these TB subs in an enclosure that will fit in the deck behind the rear seats.  Space is limited there...
38" wide
8.75" tall
7.5" deep
If its relevant the system is powered by a Kenwood XR901-5 amp. A channel for the dash speakers, B channel for door woofers and sub channel for this box.
I recommend firing the subs up towards the slanted glass but if you want to test some other direction and don't like it I guess you can change it back later.
The other thing I wanted to tell you is that you can only use like 70W out of the 400W your amp can provide, you have enough box size for a SA-8 sub or similar 8" sub which can take advantage of the extra power you have available, I am telling you this because those little woofers you have may sound nice but they are not going to get loud at all.
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
