Two 12s in custom 6th order blow through
Looking for 2 12s that have good bandwidth, will be in large 6th order blow through and needs to be 1500-2500 watts RMS and also need to be 150$- 300$ a peice. I'm currently running a taramps smart 3k at 1 ohm on a single 200 amp H.O alternator (soon to be two) and two runs of 0 guage cca.
Subs with EBP = Fs/Qes  70 or higher are possible candidates, the bandwidth comes from the enclosure.
I understand that, but I have had some subs that don't take well to 6th orders, or maybe I've never built one right.  I'm paying someone to design it this time, I'm not even sure the exact cubes ill have at this point but ide like to pick a set of subs out before they go up anymore
If you want a name the Fi SSDv4 12 is a candidate for your box type, $300 budget and power.
If a sub will do well or not in a 6th order BP depends on the design itself which should load the drivers only as much as they can take.
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
